Tow/haul button and check engine light
Jbt816
removing thread as it was in the wrong location
Yeah, the Check Engine Light and different driving probably means you're getting forced into open loop or some other mode to protect the engine - I doubt it has anything to do with Tow/ Haul.
I'm guessing the truck is out of warranty since it's used? If so, I would try replacing the bank 2 O2 sensor (Get the actual OE/ OEM replacement and not the wire-it-yourself BS) and check for any leaks, cracked manifolds, etc. If it still pops up I would probably replace the injectors on that bank.
My 2015 occasionally threw a code (check engine light) but only when I would tow. The code was for a misfire on Cylinder #5. Eventually I learned that this was an early warning to the cam & lifter failure. My shop originally replaced the #5 plugs, cap, and wires but eventually realized it was something deeper.
Good luck
