Davidmurphy02
- Jul 8, 2018
This is the first vehicle I've owned with individual pressure readings on each tire. For those of you who have had this feature for a while, how accurate do you find the sensors to be? I was getting some different readings so this morning I set each tire to 38psi, measured with a high quality analog gauge on the valve stem. Then I checked the dashboard display - 2 tires read 39, one 37, and one 40. Is this just a normal variation - is it unreasonable to expect a high degree of accuracy from the tire sensors? All four are within 2 psi of actual....I was just hoping for better accuracy than this.
