Hydroblueguy
- Dec 2, 2019
I have a air compressor and I adjust accordingly to the temperature change as I’ve seen a swing of 10 psi from fall to middle of winter here in Iowa. They have for the most part been between 35-40 for 99% of the 6000 miles!Oh yes the Michelin LTX is another great option in the highway tire game. Swing by an auto parts store and get a tire tread depth gauge. It doesn’t need to be fancy it just needs to work. Measure your tires on the outer tread and center tread and four spaces across.
Tire pressure fluctuates a lot depending on the outside ambient temperature. Our oil change intervals and tire rotation intervals are so far apart are tire pressures can change dramatically in between services. If the tires are wearing more in the center let a little air out.
If you find you have more tread in the center, let’s say 9/32 center and 7/32 on the inner and outer blocks Then while you’re driving down the road you don’t have enough air pressure in the tire and the center is actually lifting and your riding more on the inner and outer edges of the tread so add a couple pounds.
Tires really do require more maintenance and attention then what they are given. Dealerships and tire stores make a lot of money as a result from it. Preventative maintenance is becoming a lost art...
