No hemi no care but exterior looks great which still looks like a newer 5th Gen which I like.
The SO is underwhelming? Makes more HP and Torque than the 5.7l and with two less cylinders. Plus, turbo noises. PssshhhhhhInteresting video.
I like the looks of the truck. Glad they’re not making any drastic changes.
The standard Hurricane is a bit underwhelming. No more HP than the Hemi and losing that great V8 sound. The HO looks pretty exciting but wondering what the up-charge will be for that motor. Either way good to see eTorque isn’t being continued.
The EV using the Pentastar as a battery charger is interesting. Not something I would be interested in but I’m sure that will get a lot of EV fence sitters to jump over with basically unlimited range. I think those will sell much better than the full EV. Smart move by Ram having that option available.
The SO is underwhelming? Makes more HP and Torque than the 5.7l and out of a V6. Plus, turbo noises. Pssshhhhhh
Yeah my mistake on that. I even knew betterIt's not a V6. It's an I6.
The SO is also way faster than the Hemi, motortrend tested it at 0-60 in 5.5 seconds in a 6300lb wagoneer L, which is more than a second quicker than the hemi short wheelbase version. Not much more power but a really wide torque curve and lots of low end torque. The rams usually weight 5600 lbs or so... maybe slightly lighter with the new motor so should be low 5 second 0-60 compared to low 6 on the hemi. Stock hemi trucks also dont sound especially awesome... nice cold start but pretty muted the rest of the time in stock form.Interesting video.
You're assuming the RAM will have the traction to take advantage of that lighter weight.
In 2WD, even though it might be 700 # lighter, it probably can't put enough power to the ground to be that much (if any) faster than the Wagoneer L.
That's all dependant on the driver. You can't just smash the gas and expect to not spin in RWD.You're assuming the RAM will have the traction to take advantage of that lighter weight.
I'm assuming that's 100% gas mode, I think there will be situations where you won't be using it at all.Anyone else a bit surprised and disappointed after doing the math, and coming up with 20.3mpg for the "gas mode"? I know extra weight for batteries wiring and electric motors, but no trans and drive shaft. I would have thought it could at least achieve the current pentastar hwy mileage of 25mpg since it should be able to operate near it's most efficient point most of the time.
