NHjake98
Just to swap out the springs???....WOW$400 for me at the local off road shop.
I just got my Falcon suspension installed today. So far, its exactly what I wanted. I did have to add a 1/2” Wulf top spacer up front (thanks for the heads up) to get perfectly level. The front end as measured from the tow point went up exactly 3” but, I also added 35/12.50r18 Nitto Ridge Grapplers. Like I said before though, the truck is perfectly level as measured by the lower punch weld under the doors.
On road feels tighter and more sporty. They might break in a bit more though. I took the truck on some rough gravel roads nearby and I was duly impressed. The ride was very smooth at about 45 mph.
Pics or it didn’t happen:
Anyone mind divulging what they paid for install for this kit?
with you running 35 nittos do you rub? also what size of wheels did you go with and offset. I just ordered my falcons, fuel zephyr 18x9 -12 offset with 33s because i was worried i was going to rub with 35s
You’d be fine with 35s. My wheels are Method Mesh 18x9 -12 and do not rub at all on the right side. On the left side there was some very MINOR rubbing on the lower part of the well liner. Just a tad bit of trimming was all that was required. I probably could have just bent it back a little.
With this 1/2 wulf spacer i assume you would have to do it when you put the falcon shocks in the front?I just got my Falcon suspension installed today. So far, its exactly what I wanted. I did have to add a 1/2” Wulf top spacer up front (thanks for the heads up) to get perfectly level. The front end as measured from the tow point went up exactly 3” but, I also added 35/12.50r18 Nitto Ridge Grapplers. Like I said before though, the truck is perfectly level as measured by the lower punch weld under the doors.
Yeah i wondering if i should just go 35s and call the shop to just go with 35s instead of 33s. I dont want to cut or trim tho. Or just leave it and run 33s haha such a tough decision.
Nitto ridge Grappler 34” options for 18” wheelsI ordered nitto ridge grapplers in 33s. Just to be on the safe side. Dont think the nittos come in 34s tho.
First off, great job!! Your truck looks amazing. I was looking to do the same setup, but wasn't sure if i should add the wulf spacer or just set the falcon shocks at the "heavy accessory level". Did you use the "level" setting? And did you install an aftermarket UCA?I just got my Falcon suspension installed today. So far, its exactly what I wanted. I did have to add a 1/2” Wulf top spacer up front (thanks for the heads up) to get perfectly level. The front end as measured from the tow point went up exactly 3” but, I also added 35/12.50r18 Nitto Ridge Grapplers. Like I said before though, the truck is perfectly level as measured by the lower punch weld under the doors.
The only concern I would have running "heavy Accessory" is the stiff ride.
Just my two cents.
I have mone set on "level" with the wulf spacers and it rides great!
