I successfully paired my tazer DT and changed some vehicle settings (tire size and TPMS pressure values) following the instructions including the full reboot and 2 power cycles. The changes are not saving. I’ve been through the entire process 4-5 times.
Here’s what I’ve done specifically:
- put truck in run with engine off
- navigate to the audio screen
- use left arrow and cruise control bottoms to navigate through and change the tire size and TPMS settings
- use left arrow and cc buttons to navigate to and select full reboot
- once reboot finishes and shuts off, I open and close door and wait for 1 min after screen goes completely dark
- turn vehicle to run (engine off) and back off. Then open/close door and wait 1 min after screen goes entirely dark.
- turn vehicle on. Setting changes not saved.
What am I doing wrong?
