I take it you don't have tailgate warning lamp on dash? Search the forum others have enabled option with ALPHAOBD.Having issue with tailgate knowing its closed.
Issue is that it should not have to be slammed for system to know it's closed. I can close and it will lock but the dash error comes on.A big warning that appears on the instrument cluster not enough?
Now I understand your question. Mine was initially hard to close completely and it took a "slam" to close it completely. Within a couple of weeks I could close it normally. Figured the rubber stops clearanced themselves.Issue is that it should not have to be slammed for system to know it's closed. I can close and it will lock but the dash error comes on.
The reason your getting the warning is because it's not fully latched even though it appears closed. I need to give my a little had push because of the tonneau cover gasket cause some resistance when closing the tail gate. Perhaps dealer can adjust latch.Issue is that it should not have to be slammed for system to know it's closed. I can close and it will lock but the dash error comes on.
Me too, I just got used to slamming it.The way I know its not closing well is because of dash warning. If I close it normally the dash says its not closed. If I slam like old truck, then I don't get a warning.
