Tailgate
dschweers
The way I know its not closing well is because of dash warning. If I close it normally the dash says its not closed. If I slam like old truck, then I don't get a warning.
dschweers
A big warning that appears on the instrument cluster not enough?
Issue is that it should not have to be slammed for system to know it's closed. I can close and it will lock but the dash error comes on.
Jus Cruisin
Metro Detroit - I miss FL
Now I understand your question. Mine was initially hard to close completely and it took a "slam" to close it completely. Within a couple of weeks I could close it normally. Figured the rubber stops clearanced themselves.
dts828
Atlanta, GA
The reason your getting the warning is because it's not fully latched even though it appears closed. I need to give my a little had push because of the tonneau cover gasket cause some resistance when closing the tail gate. Perhaps dealer can adjust latch.
mikeru82
The Palouse
Mine was the same way on the Laramie when I first got it, but after a few times closing it I don't have to slam it anymore. The Limited has the MFT, and it was the same. No longer have to slam either one anymore.
COSPILOT
Maui
I slam the tailgate shut, if I don’t I get the warning. Doors are easy to see not fully closed, tailgate not so easy. Rams, like all new vehicles is a computer that happens to have wheels. Temperamental on a good day and annoying on a bad day.
