You have a tail gate release inside the truck not just on the key fob.All these new trucks these days have some sort of electronic or push button latch, no more manual. So if you had a tonneau cover on and the battery goes dead, how can you open the tailgate?
Yes both batteries. If the truck is dead, then what?
Then proceed with the regular "dead car / truck" routine, I guess. Open your door with the key, open the hood, charge / replace battery or jump start.
Another good argument for the rambox.That’s when you realize your jump starter and jumper cables are in the bed...
Only on the Laramie above trims. The BH and below don't have a button on the interior to drop the tailgate.There’s a tailgate release inside a 5th Gen?
I don’t see one in mine (base BH) unless it’s part of an package/trim.
You guys with the Jump Packs have them plugged in and charging by USB while driving? I see the NOCO ones use USB to charge.I keep one of those battery jump packs in the beer cooler....I mean "floor utility box" in my crew cab. I can access that even if I can't access the jumper cables in my bed
I don’t. Just top them off every six months or so. They keep the charge a long time.You guys with the Jump Packs have them plugged in and charging by USB while driving? I see the NOCO ones use USB to charge.
Can you share which unit you have? Might have to pick one up just in case.....Mine maintains the 100% charge for a long time. I usually bring it inside in January to charge it up again, but it's rarely below 90%-95%. On one of those -25 nights, my neighbor was outside trying to jumpstart her minivan. I walked out, grabbed my jump pack, put it on and her car started right up. At that point it had been sitting in my truck probably since August or September without being charged.
These things are great.
My Rebel has the tailgate release in the cab, might be because of the level 2 option, but I don’t have the tailgate open indicator like in the higher trim levels.Only on the Laramie above trims. The BH and below don't have a button on the interior to drop the tailgate.
