Sway bar noise source?
spinxt
I’ve read several member have had issues with loose sway bar links causing a rattle. I think I’ve developed this condition. Can someone tell me which end link bolts seems to be the culprit? (Top or bottom) I’ve check torque on the bottom ones and they are to spec....the top ones will require a little more effort (removing front tires).
thank you in advance!
CamsRam
I would suspect the issue is with the top bolts. I tightened one in my driveway by turning the wheel all the way in the opposite direction from the noise. I believe you will need an 8mm wrench to hold the bolt and and 18mm wrench to turn the nut (it may be 21mm).
Dusty1948
Rochester, New York
Mine were replaced under warranty after the truck was 6 months old. It was the joint itself on one side causing the noise. They showed me the parts and one was completely dry (no grease) from the supplier. Haven't had any reoccurrence of the problem.
Best regards,
Dusty
2019 Ram 1500 Billet Silver Laramie Quad Cab 2WD, 5.7 Hemi, 8HP75, 3.21 axle, 33 gallon fuel tank, factory dual exhaust, 18” wheels. Build date: 17 July 2018. Now at: 029794 miles.
spinxt
Best regards,
Dusty
Interesting, so just bad links?
spinxt
No wonder they make noise. They only cost $12!!!!
retho78
Mine is at dealership for front passenger side clunk and they diagnosed it as bad strut so ordered it but, it is back ordered for at least two weeks.
Dusty1948
Rochester, New York
Just one side was bad. They replaced both under warranty as a precaution.
Bests,
Dusty
retho78
Well folks, I got the truck back today and after further diagnosis to the front clunk noise they are saying it is front passenger side sway bar link and not the strut and it's on order.
