Suspension Recommendations?
JohnsenH20
What’s everybody running for suspension? I’ve got a 2020 crew cab short box 5.7 (4x4). Bought the truck about 2.5 years ago with 70,xxx on it and I’m now at 148,xxx. It already had fox 2.0’s all the way around when I got it and I’m sure replacing them will be coming up sooner than later. They’ve been great to me but I’m not so fond of the price tag as I just dropped about 1k into the front end this week for new upper/lower control arms, sway bar links, tie rod ends, wheel bearings. This is my everything truck and i put a lot of highway miles on for work but also pull a 6k lb camper job to job and take it out in the trails for hunting, silver lake sand dunes for play in the summer etc. not brand partial I just need something well rounded that can handle a little towing and trail but still be comfortable on the highway. Should also add the truck appears to be leveled compared to several stock ones I’ve parked next to so I’m assuming I’m gonna want something in the +2” range? Maybe this will help someone else when it’s time to pick something out in the future too
Everything you need if you have less than 500lb constant in the bed.
All you need if you have more than 500lb constant.
Since you already have Fox 2.0 the only way to go is to upgrade to King or Fox 2.5, or Thuren Kings.
Thuren Kings better because Thuren will tune the shocks specifically for YOU based on how YOU drive, your terrain, your load, etc and it's not much more expensive.
