MilehighRam
- Oct 10, 2019
Anyone know of a tint that can be used on the sunroof?
Some people like driving with the shade open. Why have a panoramic sunroof if you are going to keep the shade closed?Just curious why tiny the roof ? Wouldn’t shade protect you from sun ?
So those of us in extremely hot areas can have the shade open during sunlight hours. I got 30% ceramic on mine, and the temperature difference is very noticeable. Before the tint I could feel the heat radiating off the shade onto my head when it was closed.Just curious why tiny the roof ? Wouldn’t shade protect you from sun ?
I’m considering tinting the pano so I can tilt-open the roof to vent heat as the brain trust at Ram force the shade to fully open when set to tilt. Every other vehicle I’ve owned that had a sun roof allowed the shade to be adjusted when panel set to tilt open.Just curious why tiny the roof ? Wouldn’t shade protect you from sun ?
I’m actually wanting to open the shade 2-3 inches with the pano tilted open. Particularly when parked. That way heat can vent without direct sunlight continuing to add more heat than if the shade were closed.If I’m understanding what you’re trying to do, with the shade close, just hit the tilt open button. It’ll open the shade halfway then tilt the roof. That’s how mine does on my 2020.
Same thing if you hit open with the shade close. It’ll pull the shade halfway then open the roof.
The shade on my truck stops halfway no matter what I do, Tilt/fully open.I’m considering tinting the pano so I can tilt-open the roof to vent heat as the brain trust at Ram force the shade to fully open when set to tilt. Every other vehicle I’ve owned that had a sun roof allowed the shade to be adjusted when panel set to tilt open.
Yep. That’s what I dislike. Defeats the reason for tilt IMO. Tilt to vent but more heat comes in since the shade can‘t be opened only a couple inches.The shade on my truck stops halfway no matter what I do, Tilt/fully open.
My wife's Traverse is either fully open or fully closed since it's manually opened, and "spring loaded". Not even motorized. And tilt function vents heat just fine with shade open. Just start driving.Yep. That’s what I dislike. Defeats the reason for tilt IMO. Tilt to vent but more heat comes in since the shade can‘t be opened only a couple inches.
