Sunroof Rear Drain Grommets
rome5982
Received delivery my new Longhorn and thought I would double check the sunroof drains. The front two look good with the white tube protruding out of the grommets and grommets seated properly. However the two drains at the rear do not show a white tube protruding from the grommet? The grommets are there and they are seated properly, but no white tube. Is that how it is supposed to look? Thanks.
FTRO
Kansass
My Big Horn quad cab with single pain sunroof has the black tube sticking out of the front grommets, but there is no tube sticking out of the back grommets.... they appear to also be seated correctly. : Shrugs:
Dr. Jim
I have a 2019 Laramie. Both of the rear grommets have a black tube running through them but neither grommet was in place. I removed the carpeted panel behind the rear seats, reseated the grommets with about 1/4" to 1/2" of the black tubing revealed on the outside and sealed the grommets and tubes on the inside of the truck with black silicone adhesive.
