silver billet
- Apr 18, 2019
Do you feel like the sumo’s helped remove any of the sway?
What type of sway? Unloaded, the springs definitely helped in terms of cornering, going around corners at speed the truck just feels more planted, like it's on rails (exaggerating, but get the idea). The hellwig helped a lot, but the sumo springs did even more in that area.
To be honest, I don't think they do much to prevent truck from swinging left/right in a wind storm or when passing a semi. I almost ditched my truck in my first 3km test, even with sumo springs installed. That's a different type of sway, caused by the trailer pivoting on the hitch. I think dialing in my WDH helped the most with that particular problem. I use the Husky center line with solid bars (not chains) and the bars have to sit perfectly flat, or else they don't rub enough on the bracket holding them up; the friction from the bar on the bracket is what acts as a sway bar.
So if I had to guess; the biggest improvements is cornering (truck stays flat, instead of dipping into the corner), and vertical bounce; truck feels much stiffer. Doesn't do much for horizontal sway caused by trailer being pushed around.
