Using some textured abs plastic purchased from Amazon i made these. Not hard. Sanded the edge for a good transition and so the tonneau cover seals. This is about the cheapest solution I could come up with. There's about an 8mm overlap from the hole on all sides. Attached with a little right stuff, but a thin 3M double sided adhesive would work too.
Amazon.com: Install Bay ABS116 ABS Universal 12 X 12 X 1/16-Inch Each: Car Electronics
www.amazon.com
