M
Mdegen93
Guest
Anyone know of a good set of greasable front swaybar bushings for our trucks? Also are there adjustable end links yet?
There is a tsb about a clunk caused by sway bar and links. 20-002-19 came out 5/19Anyone know of a good set of greasable front swaybar bushings for our trucks? Also are there adjustable end links yet?
It’s not the end links that squeak it’s the bushings that hold the actual swaybar under the truckYeah but OP isn't having the issue described in the TSB (clunking while driving on the street)
He's talking about a grease-able ball joint for the sway bar end links. Which for the record, OP, I'm pretty sure haven't been made for the DT trucks yet (no idea if they're even available for other generation half ton Rams or not)
Oops, misread which part you were trying to grease! Honestly I've never heard of grease-able bushings for the sway bar mount. Usually they're not really super high quality bushings, and they're split as well. Maybe you can drill a hole through one side of the rubber and the clamp, and then add a zerk fitting?
Exactly the issue I'm facing, it is a poorly made dry sway bar bushing behind your front axle.Can someone post a video of the noise. I think I may be experiencing the same thing but it’s hard to tell exactly where it’s coming from when inside the truck. Mine usually just makes the noise when turning/ going over bumps.
Hi @Hail rebel - I am deeply sorry for the trouble. If you would be willing to follow up with me via private message to provide additional details of your most recent dealer visit to address this, I would be happy to learn more to determine how to best assist at this point.Facing the same issue. Bad sway bar bushing. Clueless dealer replaced it twice and slapped cheap grease literally everywhere and made a mess which made me stop going to them the third time. Ive been trying to find a better bushing since quite some time. Does someone have any input as my rebel sounds like a 25 year old truck on bumps and potholes, true misery due to a cheap bushing from FCA for a 60k truck I'm not pleased. Help guys !! @RamCares this is one frustrated customer here.
Hi @osage91 - If you work with your dealer for this, please be sure to let us know so that we can get you set up with further support for that process.Can someone post a video of the noise. I think I may be experiencing the same thing but it’s hard to tell exactly where it’s coming from when inside the truck. Mine usually just makes the noise when turning/ going over bumps.
Im currently going through the same thing on my 2021 ram big horn built to serve…. Truck is 8 months old but sounds 18 years old.currently waiting on bushings the dealer said.Facing the same issue. Bad sway bar bushing. Clueless dealer replaced it twice and slapped cheap grease literally everywhere and made a mess which made me stop going to them the third time. Ive been trying to find a better bushing since quite some time. Does someone have any input as my rebel sounds like a 25 year old truck on bumps and potholes, true misery due to a cheap bushing from FCA for a 60k truck I'm not pleased. Help guys !! @RamCares this is one frustrated customer here.
