2020Big4x4Horn
- Jul 19, 2020
Is there an easy way to remove the sliding cup holder from the center console?
What? The easy way is as I mentioned. You just need to split the slider. There are six compression clips that hold it together. Separate the cupholder top half at the seam and pull it apart. Done. Fairly easy.No there is no easy way.
If you get the rubber out, you will not be able to reseat it without taking apart the entire center console
