Sliding cup holder removal
2020Big4x4Horn
Is there an easy way to remove the sliding cup holder from the center console?
osomajor
I’ve got a quarter that slid its way in there; rolling coin sounds on every turn now.
Advice to open it up appreciated!
scottmoyer
The top half of the plastic can be split using plastic panel tools. The cup holder assembly is best split at the front, then worked around to the sides. If you're looking to completely remove the center slider, after the top is separated, the bottom has 4 screws that attach to 4 pieces of metal that fit into the grooves of the console to allow it to slide. Just be careful and start splitting the console at the front and carefully lift off.
Darksteel165
Massachusetts
No there is no easy way.
If you get the rubber out, you will not be able to reseat it without taking apart the entire center console
scottmoyer
What? The easy way is as I mentioned. You just need to split the slider. There are six compression clips that hold it together. Separate the cupholder top half at the seam and pull it apart. Done. Fairly easy.
