Miket2727
- Jun 14, 2025
What fuse?I fixed the problem on my truck. I doubt the fix will be as simple in many of these cases, but for me it was a poor connection with the fuse. The fuse hadn't blown but it was a bit loose and the connection was apparently a bit intermittent. I replaced the fuse and it fit much tighter, and the warning lights went away. Apparently the blades on the fuse were a bit thinner than spec.
