Got the exact same ones from them and absolutely love them! Love how tight and streamlined they look![]()
Got these from running board warehouse for $250 now they are running $371. Ionic series 41.
Link?I went with a more aggressive looking board that looks perfect with my Nitto Ridge Grappler tires. They are APS blow-molded aluminum and went on easily (after using a wire wheel to remove the lug paint). There is a little flex when my 220lb foot hits it, but not bad at all. They were only $210 on Amazon, but show out of stock right now.
Thanks for the link. I do not think these are aluminum. I believe they are ABS plastic from what I can tell. With steel brackets.
Ouch, forgive my mis-information there. The super hard plastic is over an aluminum frame. The frame is what bolts to the brackets. I still really like them.
Whoops, I saw APS in his description and my brain read ABS.Thanks for the link. I do not think these are aluminum. I believe they are ABS plastic from what I can tell. With steel brackets.
I haven't noticed any rear flex on mine but I'll keep an eye outI have these as well, they look great.
Do either of you worry about the rear flex? Mine is a little more than I'd like it to be.
Those do look good with the tires.I went with a more aggressive looking board that looks perfect with my Nitto Ridge Grappler tires. They are APS brand ABS blow-molded with aluminum frame under the plastic and went on easily (after using a wire wheel to remove the lug paint). There is a little flex when my 220lb foot hits it, but not bad at all. They were only $210 on Amazon, but show out of stock right now.
I just ordered the same ones. Look great.I put on the OEM ones that I bought from Dallas Dodge. under 500$
Did you order these? Are they the ones on eBay?
Another thread on running boards:I’m trying to make a tough decision I have a 2019 1500 Lonestar 4x4 in Patriot Blue. The decision is black running boards or polished aluminum..any suggestions?
