I sure as hell can!!!!! The change to tire size has nothing to do with how the start/stop functions....you cant really make those kinda changes that are 100% detrimental to fuel savings then complain about AS/S operation.
What happens in the winter when it's below 62 degrees and you just want to let cool air in at like fan speed 1?Unfortunately for you the system is working 100% as designed and is functioning properly. My suggestion would be to run the fan with defrost/floor mode set and see if that will help.
If you don't want ac on just set your temp point near your exterior point and let the fan blow away. This seems like you have already figured out that it will work that way.
They are absolutely not complementary to one another, as you correctly stated! But as you said, you are neither an Astro Physicist... or an Engineer.
It is a concept known as "trade offs", used in all design, maintenance, and life decisions. I am willing to give up MPG to have bigger tires, but I am not willing to give up MPG to run, ONLY, the fan.
I would like to be able to use the front defroster on its own but it's another "feature" that doesn't work despite there being a mode for it.
But it's not like there is any other option.
That's how I use mine. Auto works so well.You simply can not activate the hvac blower and not have the system on. Why not just set the system to auto temp that you like and let the fan blow. For example it was 42 degrees today and I just drove for 2 hours with the hvac on auto, temp set to 68, the fan was on at all times never turned off? Would that not work for what you want?
Other than when playing in the snow and needing direct defrost on the windshield to clear snow, I have never used anything but auto on my truckThat's how I use mine. Auto works so well.
The only time I've had it not work on auto is when I set the temp to high or low. Or when the AC is being turned on. But as long as it is at temp in the cabin, it works as intended.I've never used auto, it may be worth looking at but for this conversation, I don't know how it'd work relative to AS/S engaging and not engaging. Guess I'll soon see
If it's too hot or cold AS/S will not engage.I've never used auto, it may be worth looking at but for this conversation, I don't know how it'd work relative to AS/S engaging and not engaging. Guess I'll soon see
That's not true. We've had many over 90-degree days and with the interior temp set at 72, it engaged many times. Of course, it will start back up of I'm stopped too long and it needs to cool. Same with extreme cold. I was just in Miami with 92 and 76% humidity and it still worked.If it's too hot or cold AS/S will not engage.
So generally it will always engage except on really hot days depending on inside temp, or really cold days on the first startup.
What I said is true.That's not true. We've had many over 90-degree days and with the interior temp set at 72, it engaged many times. Of course, it will start back up of I'm stopped too long and it needs to cool. Same with extreme cold. I was just in Miami with 92 and 76% humidity and it still worked.
All based on interior temp and hvac settings for this discussion. If on max cool or heat, AS/S will not work. If tomorrow is set to a specific temperature the interior needs to be near that for AS/S to work.What I said is true.
I had it set on 68 degrees today and it was 77 outside, it would not engage until the truck was on for 15-20 minutes and was able to cool down near the setpoint..
Outside temp does not matter, inside does.
All based on interior temp and hvac settings for this discussion. If on max cool or heat, AS/S will not work. If tomorrow is set to a specific temperature the interior needs to be near that for AS/S to work.![]()
What is desired low or high temp in the hvac system?Not true for all trucks, I could get in my truck with it being 103°+ outside (and the truck have been sitting for hours), turn the AC on and have it set at low and stop for a light 1 min later and my AS/S would engage. The new controller is more aggressive at cabin temps and I suspect you don't have the newest controller (A/C And Heater Module - Mopar (68493386AC)) Its changed 3 times
