Right rear turn signal indicator says out?
Francog131
It did this to my left for a little whole then after I fixed and replaced the battery problem, it switched and now says the right is out when it's not. The only things I put in the truck was led cargo lights replacing the soft white factory ones. And a high flow air filter. That's it. Would those have someone how caused this? As much as I love the truck and it's tech...it's also driving me mental lol
I had the same issue with my 2021 Limited on both left and right sides. They replaced the wiring harnesses on both sides and that has solved the problem thus far .
