I got the cover installed yesterday, I will say the install was not easy and as straightforward as I thought it would be (I should point out I am not that handy so this was a big project for me and a buddy that isnt that handy either). It is installed and works, but I have further adjusting do. I think I need to call customer service and get some advice. One Rambox opens clean and easy the other one binds a little with the seal but opens all the way. I think with some fine tuning this might be solvable, we will see. One issue I have is you are supposed to remove the end caps that come on the factory silver rails and use an end cap that comes with the kit. I cant shut the tailgate with the supplied end caps. Looking at it I think the end caps can be notched or maybe a Dremel can cut a little off and they should work. Another issue is there is a gap from the edge of the tailgate to the edge of the side of the truck and water will get in the bed, I think some kind of foam sealant tape should fix this. The only other thing is, the supplied drain tubes that go from the bottom of the box to the holes in the truck bed are little short, I think I will need to find some longer ones to replace them with. I wish they would have supplied longer ones and you could cut to your needed length.
Overall a very well made cover, I think with some fine running and shimming it should work great. I will try and take some pictures later pointing out what I am talking about.
