MannymanX
5thGenRams Supporter
With the right tip, Dremel can definitely do the job!i have a "Dremel"will that be enough to cut it?
I grounded to the same point as the etorqueWhere did you ground the amps back there? I dont have the etorque but i have a bare bolt sticking up in the middle of that bubble tunnel of carpet where the etorque leads come out of yours. I was thinking this must be the factory ground for the etorque? Or is there a better ground under there somewhere?
You need to unbolt. I have the same thing. Ram should made them all the same when it came the backseat.Mine is a Bighorn w/ non-reclining seats. Not seeing or feeling a lanyard anywhere.
Question on this. So by trimming these down are you able to pull the back down as you pull the seat up??He's talking about these. I trim back to the withe plastic/nylon part
View attachment 52083 View attachment 52084
YesQuestion on this. So by trimming these down are you able to pull the back down as you pull the seat up??
hey john sorry it took so long to get back to you.but i finally started the "Back seat Mod".im using the "Dremell"its not to bad
I'm in the process of removing my back seat out of my 2019 Tradesman Crew Cab due to the infamous water leak. Just a question.. when cutting these hooks it allows for the back of the seat to fold down. After this is done does the back stay up... say during hard braking ?i have a "Dremel"will that be enough to cut it?
yesI'm in the process of removing my back seat out of my 2019 Tradesman Crew Cab due to the infamous water leak. Just a question.. when cutting these hooks it allows for the back of the seat to fold down. After this is done does the back stay up... say during hard braking ?
Yes, they still "lock up" normally. Trimming only changes the ability to fold them down. If you rim too much they will not lock up.I'm in the process of removing my back seat out of my 2019 Tradesman Crew Cab due to the infamous water leak. Just a question.. when cutting these hooks it allows for the back of the seat to fold down. After this is done does the back stay up... say during hard braking ?
