The Blue Beast
I am really disappointed with my remote start range. It is much shorter then my previous 2011 Ram. The dealer said it may be the batteries in the key fob. I don't believe that. Anyone else have this issue?
			If it is a factory install you can use the Sirius Guardian app, can't be dealership added though only factory.I am really disappointed with my remote start range. It is much shorter then my previous 2011 Ram. The dealer said it may be the batteries in the key fob. I don't believe that. Anyone else have this issue?
What system did you install?Or add an aftermarket remote start. I can remote start mine from anywhere in the world lol.
I've read its glitchy... I haven't bothered to use it... does it work without glitches for you?If it is a factory install you can use the Sirius Guardian app, can't be dealership added though only factory.
It glitches rarely and tells you not receivedI've read its glitchy... I haven't bothered to use it... does it work without glitches for you?
Viper alarm with gps smart start module add on.What system did you install?
Here is a kit i have used on my fiancés car. Has a smartphone capability add on also. Very nice kit.What system did you install?
				 www.12volt.solutions
				There are many threads stating that xm guardian does not work at all let alone glitchy. Mine also does not work at all. Both dealerships and fca state it being an xm issue.It glitches rarely and tells you not received
My Guardian app works about 95% perfectly. Not sure what the problems are. Every once in a while it will say failed and I hit it again and it works. And it's free.
Mine is the same wayMy Guardian app works about 95% perfectly. Not sure what the problems are. Every once in a while it will say failed and I hit it again and it works. And it's free.
Same, it's awesome at the airport starting from the plane.Mine is the same way
