HydroRebel
Well, my Odyssey battery showed up and before installing it I measured the voltage from it as received and it was 12.9 volts. Before swapping the battery I measured my current draw with my clamp meter instead of going in series with my other meter (due to the temperature outside) and I got 50mA which is pretty normal. The clamp meter is probably not as accurate as going in series but close enough. Anything over 100mA is usually a sign of parasitic drain so it seems I'm ok here. I than swapped the battery and did a remote start no problem. I sat in the truck for a bit and my settings were all gone, backup camera never worked, etc. which I was aware of from a YouTube video. Apparently with our trucks if you disconnect the battery you lose a bunch of stuff and it takes roughly an hour for everything to come back to normal (I was hoping it wouldn't happen but oh well!). I shut off the truck and watched the battery voltage drop to 12.3 volts which I thought was odd. Put the clamp meter back on and my amperage was all over the place and mostly staying over 1 amp. I'm making an assumption right now that the truck might be using a module or 2 (communication) to update all my settings again but this is just a guess. I will check this again after all my settings are back to normal.
Here's a pic of the Odyssey battery for those interested:
And here's a pic of my stock battery. It's not an AGM battery and I wish I had a pic of my 4th gen's battery because it was definitely an AGM battery. The Odyssey is 840 CCA vs the stock 730:
