If you haven't bypassed the ANC try that first. With any type of sub you need to do this.
My radio would undulate, the volume would go up and down, not drastically, but noticeably. The sound quality was subpar also. Once I installed 2 amps, speakers in the 4 doors and a sub, it stopped the undulation. I could unhook the amp and just run off of the head unit, it would come back. My thought is that the amp in the stereo has some type of issue. It does not need to push any real power with the external amp in place, so no clipping.
The dealer replaced my stereo, problem solved. It helped the volume some but still no real gain after probably 25, this is with no external amp. Sound quality improved also. With the external amp hooked up, I've never had it over 25, so I can't say.
