RECALL: Ram 1500 Models Recalled For Wiper Issues:
redriderbob
Co-Editor & Ram Guru!
Metro Detroit
Ram 1500, 1500 Classic, & Compass Models Recalled For Wiper Issues:
Estimated 553,950 Vehicles Affected Worldwide...
sinn
Anybody know the torque specs for the wiper arm?
sinn
Captain Obvious says 18 ft lbs.....
Jeffjad
Southwest PA
Thanks!
Scram1500
One paragraph of the recall states the teeth on the post were not formed correctly and it could strip. The next paragraph then states the correction is tighten the nut on the wiper arm. Shouldn't the repair be a new post?
mikkel
Iowa
I think the wiper arm itself has the issue, per the recall notice ... "built with an improperly formed wiper arm head joint that did not fully form the splines of the head joint on the wiper arm" ...
Apparently, Chrysler thinks that by tightening the nut another 1/4 turn it will finish forming the splines in the wiper arm joint. Personally, I would rather have updated replacement wiper arms installed. How much past 18 ft.-lbs. of torque is being applied when tightening another 1/4 turn?
Scram1500
The wiper arm is probably aluminum and the post steel so tightening should work. I've had a wiper strip before and cranking down on the nut fixed the problem
sinn
Mine was already torqued to 18ft lbs so I'm not messing with it unless it starts slipping...
I don't need some retard kneeling on my hood w/a pair of vice grips....
