Agreed. @19Jake edited his post with the actual door sticker, but I still find it interesting that recommended and actual manufacturer's limits are often so different. Thanks to the Tazer DT, I can change the limits of the TPMS so I don't get constant EVIC warnings on cold winter days.The tire pressure listed on the tires is the maximum pressure that the tire can hold. You should go by the recommended tire pressure from the vehicle manufacturer. I know this doesn't help answer the question from the OP!
Much lower than I expected. I will probably lower mine to around 37psi then also - I was at 39-40psiThis is the sticker for my Limited with Off road group and Falken Wildpeaks:
I usually run at around 37psi.
Does anybody know the recommended PSI for the 22" Sport Wheels with the Eagle Tires?
