Rebel wheels on a laraime psi question
Crableg85
Hello all So I recently bought a set of rebel wheels and put them on my laramee do I go by the PSI on my door or the PSI for the rebel wheels in a rebel truck?
Ratings are always on the tires. Take that with a grain of salt, since I always mess with my tire pressure depending on season and task at hand.
The tire pressure listed on the tires is the maximum pressure that the tire can hold. You should go by the recommended tire pressure from the vehicle manufacturer. I know this doesn't help answer the question from the OP!
Can anyone post the tire pressure sticker for a Limited with Falken Wildpeak tires? I cant seem to find the recommended PSI for them.
Agreed. @19Jake edited his post with the actual door sticker, but I still find it interesting that recommended and actual manufacturer's limits are often so different. Thanks to the Tazer DT, I can change the limits of the TPMS so I don't get constant EVIC warnings on cold winter days.
This is the sticker for my Limited with Off road group and Falken Wildpeaks:
I usually run at around 37psi.
Does anybody know the recommended PSI for the 22" Sport Wheels with the Eagle Tires?
2019 Rebel with 18 inch wheels (Goodyear Duratrac) 55 PSI front and 45 PSI rear.
