Rebel only tire size referral
Ok , so I've searched and searched this forum for a clean answer ,and most threads go off point very quickly! What I'm trying to find is advice on maximum tire size that will fit a STOCK NON AIR SUPENSION 2020 REBEL. My factory Dura tracs are about done, and I want to put the tallest, widest all terrain tire on without needing to level or lift my truck. Please only respond if you have a Rebel!
Thanks!
295/70/18 no mod no rub. Bridgestone Dueler AT/Revo in that size is same weight as 33" DuraTrac if mileage matters. All around traction and wear is good. Just a thought from experience.
Such a fantastic and underrated tire. I’ve had all the usual suspects and that is my favorite.
New user here hopefully not going to get grilled lol. I have rebel wheels and tires on my 2024 4x4 Laramie no ram box or multifunction tailgate. Can I go to a bigger size than a 275 without lift or spacers? Or am I stuck with 275’s?
Planning on going with BFG K03. Like the OPs thoughts, which has better clearance a 285/75R18 or 295/70R18. 275 is a little taller and narrower, less Poke at 34.8 tall x 11.3 wide, while the other is shorter and more poke at 34.3 x 11.8. stock is 33.2 x 11.0 so 285 3/4in circumference and an 1/8 inch poke vs the 295 at 1/2in circumferance and 1/2in poke. UCA is tighter on the 295/70. Either way, I will lose the muds. Does anyone have experience with these K03s on a stock Rebel? Thinking I would be open to a 1/4 shim spacer on the 295 if needed. Hoping airing down to 25 lbs will be an option.
I run 285/75/18 with front leveled and .75 spacers in the front and 1.00 spacers in the rear. No rubbing whatsever.
Where the spacers required? It seems that the new tire would come in 1/4 inch. factory clearance is 5/8 to 3/4 inch. Still room on the inside. Height might bring it into the well when at full turn. Love to know in the real world.
