DivrGuy
I think I've discovered the reason for a small portion of the Rebel's gas mileage woes. I don't think the odometer is calibrated differently than the other models, despite the larger diameter tires. On a trip to see my mom yesterday, out of curiosity, I reset my trip odometer as I passed a mile marker. After 20 miles of mile markers, my odometer read 19.4. Now I don't know how the DOT measures the mile marker placement or how accurate it is, but I took made the same comparison across two different counties on two different stretches of road, same results. That's a 3% difference, which is roughly the same as the difference in circumference between the normal 32" tires on the other models and the 33" on the Rebel. So at 16 mpg, that would actually be 16.5 mpg.
I see posts of other drivers with trucks with the ORP, that are mechanically about the same as the Rebel aside from the tire and wheels, and they are getting noticeably better mileage than the Rebel. I still think a lot of it is the aggressive tread, heavier, LT rated Duratracs. As I mentioned earlier, I read an article where a magazine compared gas mileage between a street tire (Michelin LTX M/S2) and an aggressive AT (Rick Cepek Fun Country II) which was about 13 lbs heavier. Same size tires, same truck, same stretch of road, same day, same speed. The AT's got 2.25 mpg less. Add that to the .5 from the odometer and that's nearly 3 mpg.
