Rear right fender removal
vealdj
Hi guys, I have 2021 RAM 1500 Big Horn 5.7 bed. How hard is to remove rear right fender to replace it? I don't want to go insurance part (yet). Just wonder how hard to do it.
I did front fender on my other car but I had at least some sort of instruction and it was not that hard. Any ideas how is in case of RAM?
Thanks!
MannymanX
5thGenRams Supporter
AzZona
You mean the fender flare? because I'm pretty sure that the "rear fender" is part of the bed.
If it's just the flare, then it's the same as the front, just remove some screws and pull on the tabs...
vealdj
No, actual fender, I see you can actually buy fender itself. More I look more Im leaning to insurance claim, seams like it not as easy as i though.
SD Rebel
San Diego, CA
Here is a link for mopar, but you can probably find it online for cheaper....
Opps, left side, but you get the idea. Input your data into the search on the site and get the right side and then us the part number to find them online for cheaper.
MannymanX
AzZona
Yes, you can buy the "fender" but it's welded to the bed. You'll need to cut the old part and weld the new part. A ton of body work is needed after the welding.
