Rear driver side window fuse location
Jvoyles84
My rear driver side window will not work at all. I've tried both the driver switch and the rear door's switch and nothing. I can't find the fuse I either of the fuse boxes. Am I missing something?
Jimmy07
Honorary Site Supporter
Do you know which one controls rear window?
Interior fuse box circuit breaker CB1, 25 amp, feeds the front driver side master door switch, which in turn feeds the two rear door switches and window motors. This circuit breaker also feeds the rear sliding window switch. So, if the rear sliding window works, and the front driver side and rear passenger side windows work, that narrows the issue down to the window motor itself, the two wires that go to the motor from the rear driver switch, or the ground wire on the rear driver switch.
kapinallinen2
5thGenRams Supporter
Southern Maryland.
Did you figure out what the issue is?
Not sure how readable this is but it might help.
Jvoyles84
Thank you. I plan on trying to figure it out this weekend. I appreciate all the help!
