Rear airbag conversion
I know you mentioned adding a compressor kit eventually, but as it is, do you need to add air regularly or is it holding steady for you?
It’s holding steady. Adding the air compressor is more for convenience than necessity.
Got to tow this weekend. Towed a 32’ travel trailer with a dry weight of about 7k and a hitch weight of around 800 lbs. This plus people and cargo. The rear bags were at 80 psi and a weight distribution hitch was used too. The tires were all at 60psi. The truck towed well. Super controllable for a heavier load and the airbags leveled the truck nicely. I’m not sure how people tow heavy with these trucks with stock tires and stock rear springs.
A few months later and I’m still liking the airbags. I’ve got at least 5k miles on them so far and I haven’t had any issues. They really do provide the best of both worlds. They’re comfortable when the truck is unloaded and they make the truck stable, comfortable, and level when it’s loaded.
I added a compressor kit a little while ago. I went with a generic Firestone compressor and air gauge/switch combo. rather than mount the gauge up front I decided to mount the compressor and gauge in the drivers side back floor storage area. It made everything relatively simple to wire and plumb and it’s out of the way unless I need it.
this is with the bags at 50psi unloaded which seems to be just higher than factory rake front to rear.
here’s what the bags look like mounted. These roll/unroll up or down depending on weight/pressure and travel. They look different than the other style of bag that you see that has bellows.
here’s what the airline routing looks like on the pass side. I’m not a huge fan of the style of line that was included. It came coiled and was a huge pain to route. I may replace it later if I have issues with a stainless line.
this is the airline hookup at the bag. They come with a screw in swivel fitting. It’s tight but there’s plenty of clearance.
this is where I mounted Both schrader valves using the supplied bracket. Not a huge fan because it’s a pain to get to put I didn’t want to drill holes in my bumper at this point knowing I’ll probably get on board air.
this is the passenger side just for reference.
These Air bags look like what is on our Class 8 trucks and HD motorhomes!
Wondering WHY Firestone has a foot note stating this will not fit Rebel models ??? Because it wont ride at optimal cushyness because it will take a few more pounds of pressure to get the truck up 1 more measly inch ?? WTF ?? May not fit factory air ride Rebel, but why not a coiled Rebel?
OR is there a REAL technical reason with solid engineering reasoning behind it ??
Thanks !!
