Ready lift help
Bigcountry
Hey guys need help here. Any advice appreciate. I got a readylift 3.5 installed on my Ram. The front passenger CV joint is now blown and needs to be replaced. The dealer is blaming the lift for the issue. The mechanic at the dealer said when the front tire reaches full extension the upper control arm is making contact causing the issue. Both the dealer mechanic and the mechanic who installed the lift have said that the lower control arm needs a drop to correct the issue of the angle of the CV. Ready lift claims they do not have this issue and therefore do not make a drop. I tried rough country and they said the same.
What do I do now?
Zstreet86
Sounds like you replace and go back to stock or mopar 2" kit, or replace and risk it blowing again.
XDBrad
Central Ohio
I don’t have the 3.5” but have to ask if the UCA contacting the CV is even possible and further question their statement about lowering the LCA to correct the problem, that would require a differential drop much like the Toyota’s use. I can see where not having a differential drop can cause the boots on the CV to constantly rub on itself causing premature wear and blow out but I wouldn’t think this soon. Too many folks here running the lifts with no issue for this to make sense.
Is it possible that when the mechanic who installed the lift pinched the CV boot when he pulled the hub away from the axle causing it to blow?
Bigcountry
This is what readylift is saying
Rebel13
May I ask what your measurement from center of wheel to fender is with the 3.5" sst lift. I have a 19 rebel with orp and am sitting 26" all 4 corners. I spoke to ready lift and they said it should measure 25.5"with the preload and top hat installed
Bigcountry
Thanks for the reply. Spoke with ready lift and they asked the same thing. Measured it to about 25.5 which they said was in acceptable margins. Ended up taking it to a third party mechanic and they looked at it. Thought the angles were all fine. They ended up cleaning all the grease off the boot and found a cut. They believe the mechanic who installed it cut the boot accidentally. Spoke to the installer, he ordered the parts, and replaced the CV two days later. So I’m back up and running and should be good to go. Still going to keep an eye on it. Might swap the kit out when BDS comes out with a 4in lift. I want to be able to take it on some easy trails and not have to worry about ready lifts “not for off-roading”.
Rebel13
Thanks! Mine goes in today for another look. Will post info when I get it
Rebel13
Between ready lift and my mechanic who both had multiple looks at the truck said although angles are a bit steeper than stock I should be fine running the whole kit. Had a look at my 17 that is still on the lot at dealership and had 4" lift in that. Angles on the old truck are way way way sharper than this new one. Told me I'm the Guinea pic lol
Joeyp
Jersey Shore
I have no issues with my Readylift kit beside the ride being a little bumpier with the 35's on there
