Not for me it wasn't. It works just fine once you get it adjusted correctly. But just choosing the tire size did not work. I went to a 33.5" tire from the OE 32" and the correct setting on the calibrator was 31.5" IIRC.Doesn't sound too accurate? It's not just put in your tire size and viola done?
The 35's aren't really 35's and once you put them on the truck the "rolling" diameter is even smaller. You need to know the revolutions per mile from the tire manufacturer and from that you can calculate the true tire sizeWho has bought the RC calibrator 90019
Is it worth it and does it work. Kinda annoyed with the wrong reading since the 35" tires installed
