Raptor Liner
Mhorton814
Clearfield, PA
So I know there is a bunch of Raptor Liner information out there and I’ve read good things. I ordered the 4L kit with spray gun. Now I’m wondering if 4L will be enough. Should I have gone with the 6L kit? I have a 2019 BigHorn Crew Cab with a 5’7” bed. Any leftovers I was planning on doing my wheel wells.
Yes the 4L kit is enough. I used 2.5-3L to get even coverage throughout my bed 2 coats. Then used the remainder of my 4L kit For a third layer on the bed floor. Whatever was left over I simply dusted it over the entire bed to get that oem satin finish. A6340CA3-C02D-4DE1-A17B-AD56D565460F.jpeg47F47F63-9693-4CA4-92B6-62BC9C51FBD3.jpeg
Wow, looks awesome!! I’m excited to start the prep work. Did you find it pretty manageable?
Laying down the product ie easier then expected. Take your time on the prep work, I split the prep work into a few days doing it after work a few hours at a time.
Ok, will do. Thats what I plan doing as well so I prep it well and have it right. Thank you!
a
another question, did you use a primer or adhesion promoter or anything or just spray on to the scuffed/prepped bed?
You only need to use self etch primer on any area that you sand down to bare metal or if you have any dings that you are filling in with bondo. I had a few dings on my bed so I used some primer but not for the whole bed. I also used the adhesive promoter on some of the edges that I wasn’t too confident on my scuffing skills.
I know a few people which have sprayed raptor liner on their bed and did not use either. So the choice is yours I did it just to be satisfy my self. Below is a picture of my bed right before I sprayed it the dark grey is the primer, the lighter gray is just where I scuffed down to the factory primer.
