RamBoxes/Bed Divider
GeorgiaBoy
Georgia
I believe I saw that a bed divider comes with the Ramboxes option. Does anyone know if that is the case? Anyone pickup their truck recently w/Ramboxes that can confirm one way or another.
mikeru82
The Palouse
The bed divider comes with the Bed Utility Group if you combine it with the Rambox option. You don't automatically get a bed divider with the Rambox option on 5th gens like you did with the 4th gens.
GeorgiaBoy
Georgia
Duh, should of seen that! Thanks! It notes "unavailable with some configurations" Is it correct to assume that it will come with the rambox configuration and not available with a standard bed?
mikeru82
The Palouse
Yes, that would be correct. Obviously, the Rambox bed divider can't be used with a standard bed. There is a Mopar bed divider for standard beds, which mounts to the bed utility rails. But as far as I know it doesn't come with any order-able packages, and is only available separately.
GeorgiaBoy
Georgia
Thanks so much!
