GeorgiaBoy
I believe I saw that a bed divider comes with the Ramboxes option. Does anyone know if that is the case? Anyone pickup their truck recently w/Ramboxes that can confirm one way or another.
Duh, should of seen that! Thanks! It notes "unavailable with some configurations" Is it correct to assume that it will come with the rambox configuration and not available with a standard bed?The bed divider comes with the Bed Utility Group if you combine it with the Rambox option. You don't automatically get a bed divider with the Rambox option on 5th gens like you did with the 4th gens.
Yes, that would be correct. Obviously, the Rambox bed divider can't be used with a standard bed. There is a Mopar bed divider for standard beds, which mounts to the bed utility rails. But as far as I know it doesn't come with any order-able packages, and is only available separately.Duh, should of seen that! Thanks! It notes "unavailable with some configurations" Is it correct to assume that it will come with the rambox configuration and not available with a standard bed?
Thanks so much!Yes, that would be correct. Obviously, the Rambox bed divider can't be used with a standard bed. There is a Mopar bed divider for standard beds, which mounts to the bed utility rails. But as far as I know it doesn't come with any order-able packages, and is only available separately.
I believe so but I think it is very different functionally. But I'm just learning and paying attention now as my reorder has BUG and RamboxesCan you buy a non-RamBox divider separately?
I mentioned above that you could. See link below...Can you buy a non-RamBox divider separately?
