RAM 3500 multiple electrical/computer issues
bopkyta
Hey everyone, our RAM 3500, 2020 is on the brink of collapse. Long story short, the truck is mainly used for long hauling trailers across Canada and the US, 99% highway driven, the milage is around 60k. I was driving it today, towing a trailer, as always, when a message appeared- "blind spot alert unavailable, service required" then a few seconds after "power step unavailable service required" and then a few more of these. After a while the main display went off. Also couldn't raise or lower the windows. Heat, a/c, lane control, 4wd drive, Uconnect, basically everything that was controlled through the main display was off. The left blinker also went off for some reason. I pulled over and checked fuses, doesn't seem to be an issue, so I restarted the computer by detaching the batteries, didn't help either. So I decided to go the dealer since the truck was still drivable, the closest one was 70 miles away and I was in the middle of nowhere so I didn't see many option. During the drive the truck went crazy. Everything was on and off, the heat, the display, the lights and so on. It all kept turning on and off randomly. But the worst part was that the trailer started braking by itself for no reason. I literally turned the blinker on and the trailer started braking. The only things that were still under my control were acceleration, truck brakes and the steering wheel, pretty much everything else was going nuts. The truck also drives a little rough, feels like a slight power loss, also kind of rough when idling. The dealership just told me to wait for a week until they are free enough to take a look at it. Of all ODB2 codes there's only C2100-16 which is a low voltage. The system shows the voltage to be at 14.1 which is normal, but I don't know if it's correct. Just wondering if anybody knows what the issue could be? Thank you!
1. Join HDRAMS.COM
2. FULLY SEAT ALL PDC FUSES
3. CHECK all fender/under hood grounds.
Another place to look is under the fuse box cover under the hood. I saw some discussion not long ago about some loose and missing nuts holding the cables on the control board. Intermittent problems like you describe are a nightmare to find sometimes. My last truck acted similar like you describe. Turns out it was a loose ground on the left front frame behind the front wheel. That cable ran up to the fuse box, had it's own ground.
Just an update if anyone interested. Went to the shop today, they couldn't find anything. Fuses, grounds, etc all good. Most likely the issue is a faulty module, booked another appointment in 2 days for further diagnostic.
I am experiencing the EXACT same issue. Every single detail is identical . The message appeared- "blind spot alert unavailable, service required" then a few seconds after "power step unavailable service required" and then a few more of these. After a while the main display went off. Also couldn't raise or lower the windows. Heat, a/c, lane control, 4wd drive, Uconnect, basically everything that was controlled through the main display was off.
I just dropped off my truck at the dealership. They said it will take seven days before they could even look at it because they only have one technician who deals with electronics. Did they ever resolve the issue issue with you?
Last time he was here was on Dec. 5th. 2022.
First post on this forum, long time lurker. I am having the exact same issues on a 2019 1500 BigHorn; did you find a solution from the shop? They can’t get me in until the end of the month.
will hope to check the grounds and voltage where i can.
I also am interested in what the fix for the "Blind Spot Unavailable" is. I have a 2019 Laramie having the same issue. Thanks.
For me personally it was a cracked rear tail light (LED tail lights) and once I replaced it (plug and play) it solved all the issues I had which included BSM notification, heat blasting, screen off, unable to roll front windows. Weird how a tail light was connected to all of this but I did notice there was some water in the old one.
Hope this helps
Hope this helps
I had both rear light assemblies off to inspect the connections and if there was any sign of water damage. Nothing was noticeable at all. Perfectly dry. I also disconnected and inspected the BSM module on both sides and all looked good there. I didn't need too, but I wiped all connections and put a little dielectric grease on and re-installed. BSM notification still remains. :(
