POLAND/GERMANY
Heey.
I bought a ram 1500 year 2020 with the 5.7l Hemi Etorque.
The following Problem right know is that it won't read the key and it dosen't make anything. The only thing is that on the Panel Cluster show me 2 messages. I also already connect a obd scanner to the ram and it won't read the vehicle.
i checket every Fuse.
any idea what it could be ??
kapinallinen2
5thGenRams Supporter
Southern Maryland.
i already tested 3 different RF Hubs still dosen't work everything is dry i put the seats out and the backwall cover too
Pretty sure the RF hubs need to be programmed for them to work.
The Bus is down so it could be anything from a poor/corroded connection to a bad module.
I suggest you subscribe to one of the online "shop manuals" and go from there.
Cbty2050
Could be anything on the can bus taking it down. Blind spot sensor or wiring to are an issue that has showed up before.
POLAND/GERMANY
Can u suggest me a online shop manual i don't use one of those yet
Thx allot
Ellisstrong
Atlanta Ga area
Did you make sure the battery you put in was all the way charged? I’ve had the no bus issue before but it was intermittent
theblet
Prob gonna need a scanner that can read the modules
