ramhouston
For example.. if one’s truck was built in 10/2022 but a TSB came out before then, could it still apply to their truck or would the TSB already would have been applied during the assembly??
i’m under the impression that the dealership would be able to determine whether it was or wasn’t?It should have been applied but just because it should doesn’t mean it was .
Yes, with that there is usually a build date/vin associated to the TSB. As you can see in the TSB provided it has a build date and vin cutoff point. The dealer doesn't just perform the TSB like a recall, there has to be a concern to be applied/fixed.TSBs aren't "applied" like recalls. TSBs are only performed if s customer comes to dealer complaining about a specific symptoms that apply to the TSB.
And you have to pay if your out of warrantyTSBs are only to assist technicians in trouble shooting
