vincentw56
- Aug 5, 2020
I installed the Pulsar and I have to say it is great. This is how the truck should be from the factory. My truck finally feels like it has a HEMI in it. Installation was fairly easy, but there isn't much slack in the wires, so it took a little wrestling to the everything reconnected. Changing modes is really easy and can be done "on the fly" through the EVIC. I have it set on performance and noticed an immediate difference. It is pricey, but I was able to buy it from another member on here for half price. I did purchase the cable to update it over the Internet. The cable plugs into the ODBII port and your computer through USB. You then run a program and it will update it. It takes about 10 minutes. For the cost of this, they should have included the cable. I shouldn't have had to purchase it later. If there is an issue that could be fixed with an update and you don't have the cable, you have to send the device to them for them to update. I am very happy I have this installed. I know it will need to be removed for warranty work. It would be cool if you had more control over certain things like the pedal adjustments and maybe some other things.
PROS:
Fairly easy to install
Quick on the fly changes for modes
Makes the HEMI feel like a HEMI
CONS:
Expensive
Doesn't come with the cable to update
Needs to be removed for warranty work
PROS:
CONS:
Expensive
