Jako
My 2019 Bighorn came with 275/65R/18 wheels
I have a set of 275/55R/20 Laramie wheels as per the description and picture
The load sticker has the psi for the 18 inch wheels at 36 psi
Using the tiresize.com calculator it changes the tire pressure to 41 psi.
If someone has/had these wheels could you please post the psi from the load sticker?
Thanks in advance.
20-inch Cast-Aluminum Premium Painted/Polished Optional on Laramie with P1 or P2 Equipment Groups (WRB)
Tire Pressure Calculator
Easy to use tire pressure calculator. Use our tire pressure calculator to calculate the new tire pressure needed when changing tire sizes.
tiresize.com
Thanks in advance.
