Powered Sub install?
I’ve always been disappointed in Cerwin Vega, but that doesn’t mean you will. However, and if you can fit it, the JL Audio ACP112LG-TW1 would sound incredible, and the Kicker Hideaway HS10 would most likely sound good.
As far as remote turn-on wiring, all 3 powered sub boxes mentioned have “DC Offset” which detects a signal in the high-level inputs and turns on the amp (JL also adds an additional signal sensing turn-on option). They all can also have a dedicated remote turn-on wire run from a +12vDC ACC.
If I’m installing the Kicker HS10 and I’m using the ANC-CH01, is there any reason I would need the Kicker 46KISL? Or, am I just tying the HS10 wires to the ANC-CH01, running the power and ground, the bass control knob, and calling it a day?
Also, I replaced the stock door speakers with Kicker 46CSC6934 6x9, 3 way, 4 ohm. Will they work as is with this setup, or do I need another amp to power them? They sound fine currently.
No members online now.
