I read a few threads about constant 12V from and fed the power line of my MagSafe charger to fuse 54 (position A). However, after I start the engine the charger stops charging my iPhone.
That seems really strange. 54A provides constant power...correct? I have my MagSafe charger wired into the center console power outlet circuit but with the fuse set to position 54B (on/off with ignition). It works as intended.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
