Hello everyone, I just purchased a ram with the panoramic roof. I have an issue when I try opening the shade only, nothing happens when I press it to open. However if I open the shade using the button to open or tilt the actual glass and then use the close shade button (which doesn’t work to open) it does work and closes the shade. Any reason why this might be? Basically the close portion of button works but the open doesn’t. Is there something in the settings that prevents it from opening? Or is this a factory defect and the dealer needs to replace the button? Thanks in advance.
