So I just got my truck back from the dealer for the 3rd brake light leak. After doing a thorough inspection for damage I found a paint defect under the passenger side tail light. I'm not sure if they did it or not, but the paint is cracking from an internal mini dent. Almost looks like something sharp from the inside of the panel either hit it or is currently against it. The mark is raised and is definitely not from an external object. I have an open case with a FCA specialist due to my water leak so when she calls I will bring it up. I want it documented so that if it spreads in the future, they will take care of the repair. For now I think some clear coat should hopefully stop any corrosion, but I don't want to do that until the dealer can take a look at it. This truck is only 5 months old.
Anyone else have a similar problem on their paint?
