Thank you all for the feedback. I have been researching the “sealing it myself“ approach. My thoughts are to seal the shark antenna, a gap below the the 3rd light just inside the truck frame, and the entire gap on the outside of truck between the glass and frame. Had anyone took it to this extent? I also have the panoramic roof, does any know where the water goes for this? I would assume down the sides to the front and back. I do not want to block flow paths with the sealing of all these items if all are using the same drainage path.
I am not a thermal engineer, but I do know that glass, plastic, and metal all comtracts/expands at different rates depending on temperatures. Does the seal have enough give to accommodate this? Has anyone sealed the entire window frame on the outside without issues?
By the way, I do have the driver side bottom LED that works intermittently. I have a 3rd party high dollar extended warranty with endurance that appeared to be bumper to bumper when I bought it. When I approached them they want to treat it like a headlight bulb you replace when they go out. When I took it to the dealer for this and for the dash leather coming loose at the seams and bubbling (both occurred after factory warranty), endurance would not cover either. For the light, I am looking at EBay and going to find a local upholstery company to address the dash. Dealer wanted $1200 for the lighting housing and and a couple thousand for replacing the dash.
